BlogAssist icon BlogAssist
Easy HTML markup for blogs and more
How to do unordered lists?
How do you make a list of items and turn them into an unordered list? I thought I could make a list of items, each on a single line, then copy to the clipboard and highlight all rows and choose Unordered List. But this gives me a list with a single Line Item with all my items together, vs. separate list-item tags.
Re: How to do unordered lists?
At the moment the way to do it is add the (un)ordered list first, then each line item individually (via the List Item operation).
I agree that it would be more intuitive to convert return-or-linefeed-separated lines directly into an (un)ordered list, and this is a feature I plan to add in a future version. I'll add your vote in support of that.
Thanks for the feedback!
Thanks
Thanks. I thought that had worked in the previous version of BogAssist, but I'll look forward to it in a future update.
Re: Thanks
This feature is now implemented in BlogAssist version 2.2.
