BlogAssist icon BlogAssist
Easy HTML markup for blogs and more
Setting web link values
How do I use value 1 and value 2 in creating a web link?
When I copy text to the clipboard and paste it, I get the same result for both values. Obviously, I want to have the first value be the URL and the second value the link name. I can't seem to do this in the Blog Assist window either. Can't paste to value boxes.
Re: Setting web link values
When using the system menu, it can only handle one value.
When using the floating window, you can drag in the text for each value, or use the action menu to paste (since the window belongs to a background-only application, the normal Paste command doesn't work — it belongs to another app).
When using the Services window, you can have the URL in the clipboard and select the text for the label in the current application. That is my preference for Web Links.
