BlogAssist icon BlogAssist
Easy HTML markup for blogs and more
When I use the Paragraph tag, it separates paragraphs after every comma
When I use the Paragraph tag, it creates a new paragraph after every comma. Help! I've tried in both plain text files and Word, with the same result.
Thanks.
Re: When I use the Paragraph tag...
I guess that is kinda an oversight on that one. It is looking for list delimiters, and repeating the tags. But I agree it shouldn't treat commas as list delimiters for paragraphs.
You can prevent this by removing the [Repeat] and [/Repeat] tags from the operation template, via the BlogAssist Preferences. But I'll make a note to fix this.
Thanks for pointing this out!
Comma in Paragraphs
Just a note to let everyone know that I've just fixed this for version 2.2.1. The comma has been removed as a delimiter, and bullet (•) and vertical bar (|) were added as alternatives, in addition to return, linefeed and tab.
