So I have SMS using the email method. I have it pause from 10 PM to 6 AM. It seems to work for about a day, then it stops and I receive SMS at 2 AM sometimes. Any way to debug this? Thanks.
James
Re: Pause not working for SMS
Are you auto-pausing the test or notifier?
Please show me screenshots of the auto-pause settings, and the Notifications log showing it notifying at the wrong times; those might provide some clues.
Wasn't sure how to attach so
Wasn't sure how to attach so I photobucketed them:
http://i290.photobucket.com/albums/ll269/DigiDemon/Picture2.png
http://i290.photobucket.com/albums/ll269/DigiDemon/Picture1.png
Thank you.
Thanks
Thanks for that. The notifier seems configured okay, but it does seem to be notifying when it shouldn't.
One thought: perhaps crossing midnight is confusing it; I'm pretty sure it shouldn't, but worth exploring.
Change the Auto-Pause line to 22:01:00 to 23:59:59, then add a second line for 00:00:01 to 06:01:00. Then see if that helps. If it does, that would suggest a bug.
Done and done...let you know
Done and done...let you know when it fires off again. Thank you.
