Simon Standard is in TheMacBundles: 12 great apps for only $49.95. Click here!
Simon and other Dejal apps are also included in TheMacBundles' innovative new BYOB (Build Your Own Bundle).
Simon Standard is also in VoteBundle: 20 apps started; 40,000 users cast 200,000 votes; 10 remain, for only $39.00. Click here!
Dejal now has a Facebook page; please Like it:
DNS check not working?
I've setup a DNS test, but it doesn't seem to work.
The triangle is gray, last change is n/a last failure never, next check counts down (I have it set to every 60 seconds.
I setup a ping monitor and it works fine and has a green triangle.
Have I missed something?
(for one dns test, I used the domain name www.dejal.com with all default settings)
Re: DNS check not working?
A gray triangle indicates success, but no changes. The DNS service doesn't support change detection, so will always be gray until a failure occurs. That's also why the Last Change is "n/a", for not applicable.
By default Simon uses time-sensitive status icons, which are gray when successful but nothing has changed or failed, bright green when a change occurs, slowly fading back to gray over time, bright red when a failure occurs, and orange when it recovers from a failure, again slowly fading back to gray over time.
If you would prefer simple green = success, red = failure status icons, change the General Preference to "Use simple status icons". See the User Guide for more info.
