1. I'd prefer Time Out to be a faceless app configured through a Preference Pane rather than an app which takes up Dock or menubar space. In Snow Leopard it's easy enough to select from the System Preferences dock icon's menu to jump directly to a specific prefpane to change its settings.
2. It would be nice to be able to set the volume of the sounds played in Time Out independently of the system volume control.
Thanks.
Re: Pref Pane instead of app? Independent sound volume?
Re Time Out as a faceless app, it will be for version 2. It won't use a pref pane to configure, though, but a separate application, which can be easily accessed via a system menu, and doesn't need to keep running.
I also plan to make enhancements to the notification options, including the sound one. I'm not sure if the volume will be independently adjustable, though it might be.
Thanks for the feedback!
