Reset breaks on launch
Hi David and others,
Is there a way to make sure that a break always both resets then starts when launching Time Out 2? Currently it seems that the timer picks up from whatever remaining time it was at when I closed Time Out 2.
Cheers,
Brian
Re: Reset breaks on launch
Hi Brian,
Time Out tries to preserve the due dates when you quit and re-launch. If it wasn't running for a while, so the break would be due in the past, it will reset them as needed.
You could use the option in version 2.1 to reset the break after a natural break. See the blog post that mentions it.
