Notifier Script Causes Crash
The command below, when placed in a notifier script, causes simon to crash.
echo "Hello world" | nc (server IP address) (port)
The nc stands for netcat. The purpose of this script is to send an arbitrary message to the logging service we use. I can run this command from the command line and it will work just fine, and I will see my chosen text appear in the logging service's logs, but when run in simon it causes an instant crash.
Exception Type: EXC_ARITHMETIC (SIGFPE)
Exception Codes: EXC_I386_DIV (divide by zero)
Exception Note: EXC_CORPSE_NOTIFY
Full crash log attached.
AttachmentSize
Crash Log.txt75.29 KB
Re: Notifier Script Causes Crash
Thanks for the crash report; I'll investigate and see if I can fix it for the next release.
