Timeout 2.2 breaks due time is messed up every morning
After updating to 2.2 from 2.1 breaks don't work every morning.
I use normal (10 mins per hour) and micro (20 sec per 20 min).
During work day everything works smoothly, but every morning when I wake up my Mac timers are due in 10+ hours.
Seems like the throw away day part of due time and check only hour:minutes part.
To make it work again I have to start/stop break manually.
AttachmentSize
экрана 2017-03-17 в 10.23.42.png9.63 KB
Re: Timeout 2.2 breaks due time is messed up every morning
Hmm, I have had a couple of similar reports. I can't reproduce this issue, though.
I suggest that you turn on schedule logging to help diagnose this:
1. Go to the "Advanced" page of Time Out's preferences.
2. Turn on the "Output scheduler logging" checkbox (and leave the "significant changes" one below it on).
3. Reproduce the issue.
4. Look in the Console's system.log to see the Time Out logging lines.
5. Copy the lines from a few minutes before and after the issue, and send them to me (either paste in the lines in a reply here, attach to your original post, or email to me.
Disregard that — I have figured out the issue, thanks to discussion elsewhere. I'm fixing it for version 2.2.1.
Just in case, I've collected the log, but nothing interesting there.
Works fine until sleep, after wakeup in the morning, due times are incorrect:
For Normal break: 11 hours 50 minutes
For Micro break: 11 hours 20 minutes
Please install version 2.2.1 (released yesterday) and confirm that that fixed it.
