Timer problem
I want to work 15min and have a 15minute break, so I've set the timer as the attached image shows. 15min break every 30minutes. As you can see in the timer to the left, the timer shows its like 26minutes between break (due in xxx + done xxx ago). It is the highest order break, so that shouldn't matter.
Whats wrong/what can I have done wrong/or don't understand?
thanks
/Andreas New user
AttachmentSize
Skärmavbild 2017-04-03 kl. 10.01.13.png126.69 KB
Re: Timer problem
Hi Andreas,
When you leave your computer idle, it will count backwards, to give you credit for your "natural break". That can change the amount of time between breaks.
If you don't want that, you can change the natural break option.
