Timer works incorrectly
The timer on Normal break works incorrectly.
As you can see, it shows 45+ minutes even though my interval between breaks is set to 30 minutes.
Re: Timer works incorrectly
I have occasionally seen this too. I'm not sure why; I'll investigate for the next update.
Resetting the breaks will fix it.
