Text in Text Theme doesn't display without cursor click
The text in my Text Theme doesn't seem to display until I click on it. From my view, this is a bug, but is it intended as a feature? Opacity is set to 75%
Re: Text in Text Theme doesn't display without cursor click
That is not intended. I seem to recall seeing another report of this, but I can't find it right now.
Are you using High Sierra, or an earlier macOS version?
I'm using Sierra 10.12.6
Hmm. One thing you could try is to use a different color for the background. I think some colors might make the text hard to see.
