As with the "Simon" product, I have been unable to 'activate' the sounds that come packaged with the application (or any Dejal application). When I select them, they do not play. I am running Snow Leopard with all current updates.
The NATIVE Mac sounds will play (as they are also options in this package, but not within Simon)… but the NEW sounds provided with the software will not play at all (buzzers, flexatone, orchestra, etc.).
Is there something I must do to activate these sounds/actions?
Thank you!
Re: Packaged Sounds Not Playing
See my response for Simon.
Thank you. I responded to you under that forum topic. :-)
