Great new version thanks.
I have 3 monitors and have set the appearance on screen option to my centre monitor. The tree/hammock icon appears on the centre screen, but the break controls appear on what ever screen has the active menubar, I would expect the break controls should be fixed to the centre monitor as configure.
Cheers
Re: Break controls multi monitor window placement
Yes, the break control panel appears on the active screen, so it's near where your mouse pointer is.
I may add another preference to control where it appears, if others have strong views of where it should be. Or always make it appear on the theme screen, at least by default.
