Hi, is there any possibility to delete all cookies from all running tests at once? or for single tests? I only found the "-" button directly in the test, but maybe its possible to use a script like "delete every cookie all 60 min" or something? Thanks in advance.
Re: Cookies in Simon
No, using that button is the only way, unless you want to edit the data file directly (it's in an XML plist format).
