Caboodle is temporarily unavailable for purchase. Stay tuned!
Caboodle icon Caboodle
Lean, clean snippet machine
where exactly is Caboodle data saved?
Hi, I'm trying to backup my laptop and am having the hardest time finding the actual Caboodle database. Under advanced it says that it should be at ~/Library/Application Support/Dejal/Caboodle but I am not finding this folder anywhere. Also I cannot change this location; the line is uneditable. Can someone tell me exactly what file(s) I should be saving so that when i reinstall Caboodle I'll have my full database back?
Re: where exactly is Caboodle data saved?
The data is in that location. Note that the Library folder is hidden in recent OS versions; you can see it by pasting that path into the Go > Go to Folder... window in the Finder.
You can change the location by clicking the Set button, but probably shouldn't unless you have a good reason to do so.
