Bug: 2018 MacBook Pro - Postpone & Skip Button Disable Time Problem
I've been experiencing a bug where I have my break set to disable the Postpone and Skip buttons for ten seconds, but the buttons become available just under three seconds.
I'm running on a 2018 MBP with High Sierra 10.13.6 and Supplemental Updates 1 and 2 installed. I believe I had the same issue with my pre-replacement 2018 MBP several months ago. My late 2013 iMac did not exhibit the same problem.
Thank you.
Re: Bug: 2018 MacBook Pro - Postpone & Skip Button Disable ...
Hmm, that's strange.
Please try using the 2.5 beta, if you aren't already, to see if that helps.
If not, please email me a screenshot of the Break Schedule page, to see if I can spot any clues.
You could also turn on scheduler logging in the Advanced preferences, and email me the Console lines from during a break when the buttons activate too soon.
Thank you for your reply. I've sent you an email.
